Headphone amps
Discussion in 'Headphones, Earphones & Portable Music' started by slingshot, Aug 29, 2003.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Anyone recommend a good, cheap headphone amp, decided I need to dig my phones out to stop annoying the neighbours, used to be OK cause my Arcam Alpha power amp had a headphone socket however the new P85 doesn't.
    Slingshot
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Actually might invest in some nice new phones aswell to replace my ageing HD480's.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    The Creek headphone amps are very good value ( www.creekaudio.co.uk ) and there are 2 models,the OBH21,and the SE model.....both very good little amps.
    If you wanted something a lot better,then the Earmax ( http://www.audiophileclub.co.uk/earmax.html ) is superb(I can vouch for that personally) and also the Headroom amps from the US are superb.
  4. NicolasB
    NicolasB
    Oct 3, 2002
    5,867
    Emily's Shop
    +564
    Depends what you mean by "cheap". Rega do a fairly low-priced one, and of course there's the Fidelity X-Cans V2.
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Does anyone with x-cans now if using a splitter they will drive 2 sets of cans ?
    The creek one has 2 inputs I noticed.
  6. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    For that sort of purpose,I'd say the Creek is probably a better choice,esp the SE model.
    For sheer quality(but only for one set of 'phones) the Earmax is pretty much unbeatable...not only to my ears,but in a number of comparative reviews Vs the Naim and X-cans etc,it comes out way ahead....for value though,the Creek is excellent.
  7. NicolasB
    NicolasB
    Oct 3, 2002
    5,867
    Emily's Shop
    +564
    If you're seriously considering an Earmax then you should also check out the "Solo" from Graham Slee Projects. Note that either is ~£400, so it might not meet your definition of "cheap".
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    some good historical threads on this as well.
    What about a second hand pre / integrated?
    Anmyone heard the new Musical Fidelity yet, v3? looks nice
  9. Mr.D
    Mr.D
    Jul 14, 2000
    11,049
    +1,126
    The Xcan V2 can normally be found on ebay for not a lot of cash.
    They can also be fiddled with quite abit to improve sound quality: check out the thread in DIY.
  10. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Found them new for 109 quid, which sounded pretty reasonable, however I wanted 2 sets of phones aswell!
    Also looked at the project headbox which has lots of inputs/outputs and 2 volume controls, haven't heard anyhting about them though and I guess it's a comprmoise with all those switches etc.
    Saw the Graham Slee ones, and it's a bit outside my price just for occasional nighttime use.
    Slingshot
    (saw the DIY thread on modifying the X-cans and may be tempted if I can find the bits)
  11. Garrett
    Garrett
    Apr 21, 2001
    32,229
    2
    167
    The best thief you’ll never see.
    +4,197
    You may not need to buy an amp, if you have a recording device that has a phone socket just send the signal to it (in some cases the record button in pause status may be needed) and you can alter the volume by ether the input levels or better still the phone levels.
  12. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Nope, no recording device at all ! My tape deck died and was crap anyway and there's now't worth connecting up a video or PVR for.
  13. Garrett
    Garrett
    Apr 21, 2001
    32,229
    2
    167
    +4,197
    That’s blown my next suggestion as I was going to say the video.:(
  14. Uncle Dicky
    Uncle Dicky
    Have a look at the new Musical Fidelity headphone amp, which is ow in its third version. As if the looks aren't enough its perfrmance is unrivalled!
  15. NicolasB
    NicolasB
    Oct 3, 2002
    5,867
    Emily's Shop
    +564
    (loud cough)
    Unrivalled at that price level perhaps, but even that's a matter of opinion.
  16. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    Not sure what you base that on,Dicky,especially when you have things like the Earmax Pro,and if you really want to go for it,the Headroom Max and Blockhead.....I'm afraid the sound quality of all of those makes the MF look a little less competitive....they are of course a bit more expensive,and the Earmax's looks are not to die for.
  17. Mr.D
    Mr.D
    Jul 14, 2000
    11,049
    +1,126
    Stick some alternative valves in your Xcans easy to do and a big improvement .
    Now to replace the caps mwahahhahhahhaa!
