Headphone amplifier for Denon AHD-550?
Discussion in 'Headphones, Earphones & Portable Music' started by bazac, Sep 8, 2004.
  1. bazac
    bazac
    Hello,
    Do I need a headphone amplifier for Denon AHD-550 (Impedance 35 ohm)?
    I want to use it with my iRiver H140 (Impedance 16 ohm)
    Thank you,
    Daniel
  2. alexs2
    alexs2
    Nov 13, 2002
    13,959
    +1,671
    No...you're unlikely to need an amp specifically for that,and will likely only notice a slight loss of maximum volume.
    If you were interested in a portable headphone amp at some stage(some of the IC type amps in portable players can be a bit edgy at higher volumes)there are plenty of alternatives,but the Headroom range from the US are designed for portable use(most of them anyway),and mostly of good to excellent quality.
    www.headphone.com
