Headphone Amp for Sennheiser Momentum
Discussion in 'Headphones, Earphones & Portable Music' started by OMGArron, Sep 1, 2013.
  1. OMGArron
    OMGArron
    Apr 5, 2013
    10
    Hello,
    I have a set of Sennheiser Momentums and I am looking for a portable amplifier that will run off of batteries so I can take it with me to university and use it on commutes to and from university and home.
    Thank you in advance.
  2. reinheart
    reinheart
    Feb 11, 2013
    19
    I have a Graham Slee Voyager Headphone Amplifier as my buddy so I can enjoy the best of my music while traveling. :thumbsup:
  3. OMGArron
    OMGArron
    Apr 5, 2013
    10
    Thank you.
    I have seen that one online it did look nice. I suppose I'll have to either buy it or put my faith in a shop somewhere as you're my only reply bit annoying actually.
    Thanks again.
  4. jamung
    jamung
    Oct 24, 2011
    234
    28
    +28
    FiiOs are good portable amp. I'm using E11 for my M50 and it adds more depth. Long lasting battery(around 13hrs+ continuos via single USB charge).
  5. OMGArron
    OMGArron
    Apr 5, 2013
    10
    Wow that sounds very good thanks.
    Thanks guys.
  6. Jan Pogonowski
    Jan Pogonowski
    Oct 14, 2008
    461
    28
    Crewe
    +27
    With an 18 ohm impedance, I'd have thought the Sennheiser Momentum headphones wouldn't really need a headphone amp for portable usage.
  7. MarkLG
    MarkLG
    Dec 31, 2008
    213
    +7
    I've just got a Fiio E7 to drive my new Momentums. Managed to pick up an ex-display one on Amazon for £40!
    You can run the Momentums straight off an iPod or iPhone, but you won't be doing them justice. A relatively inexpensive portable amp will make a real difference to the sound you get out of them.
  8. OMGArron
    OMGArron
    Apr 5, 2013
    10
    That's what I thought to be honest my phone (S3) seems to drive them very well but I know that an amp will increase this performance and it would also improve output from my PC.
    Thank you
  9. c64
    c64
    Jan 25, 2008
    42
    +8
    A fii0 e5 will do the job very well fantastic little cheap amp good enough to drive anything under about 250ohm I'd say.
  10. OMGArron
    OMGArron
    Apr 5, 2013
    10
    Thank you. It seems I still have a lot of research to do.
    Thank you so much guys I am very grateful.
  11. disco41
    disco41
    Sep 16, 2013
    I have a fiio e6 connected to my Galaxy s2 using goldring ns1000 headphones and for the money they sound really good.
    The e6 seems to be able to keep the music more under control it's tighter the bass and treble stronger.
  12. Snakemanstu
    Snakemanstu
    Aug 29, 2010
    1,285
    Herts
    +180
    Would the fiio e6 work on a samsung tablet?Is it just a case of connecting via 3.5mm headphone socket then headphones into the fiio?I also have some momentums but when using on my tab for movies volume isnt very high even maximum.
  13. rousetafarian
    rousetafarian
    Aug 17, 2007
    23,189
    2
    NW
    +15,186
    My FiiO E11 and B&W P5's sound sweet together plus a spare battery for long-haul flights helps too
  14. Snakemanstu
    Snakemanstu
    Aug 29, 2010
    1,285
    Herts
    +180
    Well purchased the e6 fiio...amazing for the money very impressed!.:D
