Headphone advice please
Fiesta Red
As I get older, my hearing is not as good as it was so I'm thinking of using headphones to help. I've never had any before so I'm at a complete loss as to where to start.
I have looked at TV listeners but they seem to pick up and amplify other sounds within the house and that's what led me to the headphone idea. The TV is an LG 43UK6470PLC and I'm not even sure if it takes headphones in the old fashioned way of a jack plug.
Any help, advice or pointers in the right direction would be most welcome.
GaryPSU
Get a Bluetooth transmitter with the APTX low latency codec. Also get earbuds/earphones with the APTX low latency codec. These wireless items with that specific codec will allow the voice to be in sync with the picture. Various varieties of both are available at Amazon. Total can be less than $60. Easy hookup. I use them to watch TV in the bedroom without disturbing my wife after she falls asleep.
Fiesta Red
No disrespect to Gary with the reply above, is there no one from the UK that can help or advise? I thought this would have been a pretty simply one for you knowledgeable guys.
Fiesta Red
Thanks for the help Gary, really appreciated. Do you have a link to anything you mentioned at all please? Not having a clue what I'm looking for, it would be a great help.
leckie
My recommendation would be picking up a good set of bluetooth headphones. You don't need a bluetooth transmitter as your TV already has bluetooth built in, it's just a case of changing the source in the audio settings.
As for recommendations on a particular set of headphones, that would really be determined by budget. However if you're going to be wearing them for a while I'd go for something comfortable, e.g. a good set over over-ears. You can't go wrong with the Sony XM3/XM4's but that may be outside of what you were hoping to spend.
Fiesta Red
Thanks for all the help Leckie, really appreciated.
Having had a quick look on Aamazon but with a budget around the £100 mark, the Sony ones you mentioned are a little on the high side. Didn't realise there were so many and in such a wide range of prices.
Can I ask how the Bluetooth headphones plug in to the TV?
JayCee
They don’t. They’re wireless.
You set your TV Audio output to Bluetooth and “Pair” it to any Bluetooth wireless headphones.
It's just a case of picking a set of on-ear or over-ear headphones to suit your budget.
Amazon have a reasonably cheap brand which get good reviews and I've seen them recommended here in the forum.
Amazon product
Fiesta Red
Amazon product
Brilliant, thank you. Apologies for asking what may seem dumb questions but when using the Bluetooth headphones, does it cut the TVs speakers out? I'm the only one listening so it wouldn't be a problem.
JayCee
Yes, it probably will.
Some brands (e.g. my own Panasonic) give you the option of using the speakers and wireless headphones at the same time but I don't think LG does.
leckie
JayCee has made some good recommendations. I can confirm too that the sound will only come through the headphones when you select bluetooth on your LG TV. No dumb questions either, it's why the community is here to help.
If you have one near you @Fiesta Red, Aldi and Lidl quite often sell Bluetooth headphones and earphones ;)
Fiesta Red
Had a quick look at the TV and the Bluetooth in the sound section is greyed out. Will this change when I get headphones and switch them on please?
GaryPSU
I have my Bluetooth transmitter attached to the audio out plugs on my cable box. That way the tv speakers and earphones work independently. That’s why I recommended a transmitter and earphones. You don’t need high quality. It’s only for tv sound. I don’t know what’s available in the UK, but don’t forget that both items should have aptx low latency or the picture and sound will be out of sync. Good luck.
Fiesta Red
Another question if I may, will I be able to charge the EP650 headphones from one of the USB ports on the TV?
Reading the EP650 manual online (waiting for the headphones to arrive) it just says charge from a powered USB port.
JayCee
As long as the headphones required charging current doesn’t exceed 1A you can probably get away with charging them from the USB port on the TV intended for use with a HDD.
They are usually clearly marked beside the port or the TV's user manual will show you which one.
The following is stated in the 'User Manual': -
Fiesta Red
Thank you for posting the information. Is there any way I can find out what voltage the USB port on my TV is please?
A USB-A port connection is standardised at 5 volts DC (since 1996) for all devices...
JayCee
But make sure you use the USB3 port marked “HDD” as that can supply close to 1A.
A standard USB2 port can only supply a max current of 500mA.
LG G1 OLED Evo TV and SVS SB-1000 Pro subwoofer reviews, Samsung OLED rumours and more...
Latest News
BAFTA 2021 awards sees Nomadland as big winner
  • By Andy Bassett
  • Published
What's new on Netflix UK for May 2021
  • By Andy Bassett
  • Published
Samsung rumoured to be buying OLED TV panels from LG Display
  • By Andy Bassett
  • Published
Netflix signs with Sony for first streaming rights in U.S.
  • By Andy Bassett
  • Published
Audio Pro launches C10 MkII speaker
  • By Andy Bassett
  • Published
