Head Cleaning on Drawer Loading Tape Deck
Discussion in 'Hi-Fi Stereo Systems & Separates' started by warrj, Sep 19, 2003.
  1. warrj
    warrj
    I have an old Denon tape deck which I'm thinking of putting back into service. It uses a drawer loading mechanism (like a CD player). This means that I can't get at the heads to clean them.
    Any ideas?
    BTW I've heard that 'Head Cleaning Tapes' aren't such a good idea from the PoV of head wear - is this true?
    Regards,
    Jules.
  2. jont
    jont
    Apr 8, 2002
    4,242
    near Aylesbury
    +545
    I always used to use the 'wet' type cleaning casettes ... can't remember who made them ... but had a little pad that you used to soak with isopropanol and it wiped back and forth on a little plastic spring driven by one of the spindles ... also had a second pad that would clean the c**p off the pinch roller ...
    Jon
  3. Chrissywis
    Chrissywis
    Jun 8, 2003
    146
    16
    London
    It sounds like the Allsop 3 cassette cleaning system. No idea if they are still made though. I haven't switched my cassette machine on for years:D
  4. jont
    jont
    Apr 8, 2002
    4,242
    near Aylesbury
    +545
    Thats the one ;-)
  5. andymc
    andymc
    Sep 18, 2003
    266
    Bedford
    +15
    They are Allsop 3's and they are still made. I saw them in Comet the other week and they are about the best cleaner on the market for Cassette Players... You should also look at getting a head demagnatiser if you are serious about this. TDK do them and you can see them at
    http://www.tdk-europe.com/products/uk/accessories/01
    Regards
    Andy Cuthbert
