Hdx710
Discussion in 'Blu-ray & DVD Players & Recorders' started by Breslin1888, Mar 24, 2006.
  1. Breslin1888
    Breslin1888
    I recently bought an HDX710 with integrated freeview and have read various threads saying there is a manual work around for ammending the start\stop rec times for EPG recordings, does anyone know what the work around actually is?
  2. Breslin1888
    Breslin1888
    :lease: anyone know this much moaned about workaround for the hxd710??
  3. MRH15
    MRH15
    Mar 9, 2006
    11
    +14
    Select programme from EPG, select TIMER, then select MODIFY, make it a repeat program for each Monday etc., this creates a manual timer entry. Exit the EPG and select TIMER, select the program entry in the list and select MODIFY, you can then change the start and end times to suit. Long winded but functional, or you could go back to manual entry like we all had to with VCR's!
