HDTVtoMPEG2
Discussion in 'General TV Discussions Forum' started by Dr Nick Riviera, Nov 8, 2004.
  1. Dr Nick Riviera
    Dr Nick Riviera
    Trying to find a guide on how to use this proggy, does anyone know of one? I have tried following the instructions on the actual download page, but after waiting 30 mins for it to convert, I ended up with a 2KB mpeg file!! The source file is 6GB!
    The only thing I don't quite follow is what should be in the Channel drop down menu - at the moment it is blanked out and I can't enter anything manually.
    Sorry if I am asking a dumb question - my first dabble with HD files!
    Nick
  2. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    ...no probs here - although I only use it to join ts files to one large ts file.
  3. dvdmike007
    dvdmike007
    my copy wont do that at all its realy anoying
  4. rogeralpine
    rogeralpine
    Oct 28, 2002
    573
    16
    ....just download the latest version.
  5. dvdmike007
    dvdmike007
    i have 2 versions in a row and it wont do it
  6. mattmarsden
    mattmarsden
    Mar 6, 2002
    1,593
    63
    +102
    You need to use TSreader to find the PID values for the video and audio stream and enter these in HDTVtoMPEG (these values take the format, for example, 0x44 and 0x45)
  7. dvdmike007
    dvdmike007
    will try that thanks
