Hdtv
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rasczak, Aug 7, 2003.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Whilst not exactly 'breaking news' it does look as though the wheels are starting to roll on European HDTV.
    http://www.whatvideotv.com/news/fra...atvideotv.com/cgi-bin/displaynews.php?id=4500
    (Hope the link works - if it doesn't goto the Electronic News Page)
    Of specific interest is:
    Can't come a moment to soon in my book.
  2. sparkybun
    sparkybun
    Jan 6, 2002
    1,186
    41
    EN8 area
    +23
    Rasczak, to a complete novice what are the benefits of HDTV? Could you give some Pixel resolutions or something that can be a meaningful comparison. Is it only for satellite broadcasting or will DVD's be in HDTV format soon?
    Thanks in advance
    Mel
  3. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    sparky bun
    HDTV resolution is 1920 x 1080 known as 1080i or 1080p depending on whether the signal is interlaced or progressive scan. There is also a semi high def res of 1280 x 720. (720i or 720p)
    It will be satellite or internet download only at the moment as DVD cannot hold enough data - high def will probably need 5 times as much data as it has 5 times the resolution of PAL anamorphic widescreen - 720x576.
    That would give you only 48min on a dual layer DVD.
    Blue ray or Holographic disc will remove this obstacle with their much increased capacities.
    Cheers,
    Cal.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    Well as Calscot posted higher resolution. For home cinema users it should be a greatly improved picture - especially for projector and large screen users.
    We will probably see High Definition DVDs marketed on BluRay disks. I think it is very unlikely that it will become the defacto standard as many programmes will not benefit but we may see special HD-DVDs take the market currently held by Superbit DVDs.
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,499
    2
    71
    High Wycombe, Bucks, UK
    +59
    For recording HDTV you'll want a JVC D-Theater D-VHS deck, it's the only thing I know of that can record HD, other than a PC.
  6. sparkybun
    sparkybun
    Jan 6, 2002
    1,186
    41
    EN8 area
    +23
    Hi all,
    Thanks for a very succinct and informative answer. Yes I can see what a dramatic increase in resolution and therefore better picture it will give. Does this then mean better plasma screens/televisions to handle the increased resolution?
    cheers
    Mel
  7. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    Yes, you will be able to buy HDTVs.
  8. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    Samsung have recently demonstrated a 70" 1920x1080 resolution plasma. Mmm...can't wait! :smoke:
    Steve
  9. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Sport is one of the types of programs that will improve the most, for example, on wide shots, football players faces, instead of just being a smudge, might actually be almost recognisable.
    Cheers,
    Cal.
