Hdtv
Discussion in 'General TV Discussions Forum' started by juggajatt, Oct 21, 2005.
  1. juggajatt
    juggajatt
    I have a Toshiba 36ZP48 with which i am totally happy with but was wondering is there any way i can get HD pictures on it(by using external equipment)or will it one day be totally out of date as with all CRT tv sets? :confused:
  2. davidhunter
    davidhunter
    Feb 19, 2003
    229
    28
    Glasgow Scotland
    +26
    Hi juggajatt,
    I think your tosh is very similar to mine the 36zd26p which I just posted up almost the same question. I am interested in finding out the same thing anyone help both of us?
    Davy
  3. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    As with 36ZD26p, the manual doesn't mention HDTV resolutions so the assumption is that it DOES'T support HDTV...
  4. davidhunter
    davidhunter
    Feb 19, 2003
    229
    28
    Glasgow Scotland
    +26
    Got an interesting reply finally from Toshiba about this, leaves me in the dark still about what is the native resolution but have a read and see what you think !! There is maybe some light at the end of the tunnel
    David
    FROM TOSHIBA
    Dear Mr Hunter,
    Thank you for your recent enquiry. Please find the information that you requested as follows:
    We do not have the information that you require however we have been advised that the tv will support the HD signal
    If you have any further queries or would like to go through your query with an advisor you can contact us on 0115 9766958,
    Monday - Friday 8.00-20.00, Saturday 8.00-18.00 and Sunday 10.00-16.00, or feel free to reply by E-mail.
    We trust that the information is to your satisfaction. If you have any further queries, please do not hesitate to contact us on the above number.
    Kind regards,
    Dean Morledge
    Toshiba Consumer Products Division Helpdesk
    JUST FOR INFO THIS WAS MY QUESTION
    Dear sir/madam,
    What is the native resolution of the 36ZD26P TV in pixels both vertically and horizontally ? Do you know will it be able to support any of the up coming HD TV codes via component input ie. 720p or 1080i
    Thanks for any info.
    David Hunter
  5. boyimace
    boyimace
    Jul 3, 2005
    442
    +5
    Hi, just a note for you guys, for those of you who have a Xbox 360 then if you're connected via component input then you are by default running on ED (extended definition - 480i) if you go to the settings on Xbox Dashboard and go to Video and change the HD to 1080i it will work! But the screen seems to large for the TV, 720i blue screens and i'm searching high and low to see if I can get HD running on it properly.
    Ta
  6. Eiji
    Eiji
    Feb 16, 2005
    1,423
    48
    +70
    Why not try accessing the service menu when the TV is running at 1080i and adjust the HORIZONTAL and VERTICAL settings?
  7. boyimace
    boyimace
    Jul 3, 2005
    442
    +5
    Thanks for that will try that.... when i get the guts to mess around with them
