HDTV without HD programming?
Discussion in 'TVs' started by ALL_DONE, Dec 5, 2004.
  1. ALL_DONE
    ALL_DONE
    What happens if if just run regular cable on an HDTV say 47"??
    is it really fuzzy? or what?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    depends on the quality of the source and the display are you US based???
  3. ALL_DONE
    ALL_DONE
    i am getting rogers...canada..just regular cable...will that show up blurry in HDTVs?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    not if the HDTV has a good enough scaler but you may want to make room in your budget for an Iscan HD or Lumagen Processor to scale SD cable to HD for TV to display try over at www.avsforum.com a US based site as this one is UK European based
  5. Master Rahl
    Master Rahl
    Nope. :) Cogeco shows just fine on a HD TV.
  6. ALL_DONE
    ALL_DONE
    JVC AV-48WP55 48" Digital Widescreen HDTV $1300cdn
    Panasonic PT47X54 47" Digital Widescreen Projection TV $1600cdn
    Sony KP46WT510 46" Widescreen HDTV $1500cdn
    Which is the best?
