HDTV with ps2 x box and gamcube
Discussion in 'Xbox Forums' started by Lobo Soulman, Mar 28, 2006.
  1. Lobo Soulman
    Lobo Soulman
  2. PrivatePile76
    PrivatePile76
    Sep 28, 2004
    517
    28
    +27
    Well I'm sure it will look lovely...
    but playin original xbox and the cube won't benefit from having a HDTV because they can't input a HD signal...
    the PS3 will though......when you get one.....lol
    get ureself a 360.....that will look lovely and they are now readily available...
    When I bought my HDTV in prep for the 360 I plugged my original xbox into it and to be honest I thought it looked weird !
    HALO2 showed up all sorts of background colours and stuff that wasn't there before..
    sorry I'm no massive technical guru with this stuff but I know the basics..lol
    a HDTV will show any flaws in any broadcast (sky for example) or on any non HD consoles...
    as I said it will still be a good buy....but don't expect the xbox or cube to look amazing because they won't...
    Bob
  3. VILLAn66
    VILLAn66
    Jun 23, 2005
    605
    West Midlands
    +8
    ... and why ask in the XBOX 360 forum? :confused:
  4. Lobo Soulman
    Lobo Soulman
    Well I have a 360......
    I just figured there must be loads of people who have a 360 and older consoles as well and would ahve tried them because i heard that the ps2 can look weird through it.
    Thanks :hiya:
  5. Binternet
    Binternet
    Oct 30, 2004
    190
    Sunderland/Newcastle
    I have my xbox and PS2 hooked upto to my HD via components and while they look better than scart they still look a bit odd compared to CRT. Takes a while to get used to, but if you have a prog scan PS2 game, or get your xbox modded to output 720p it will look fantastic.
  6. Throttle
    Throttle
    Sep 28, 2004
    1,836
    Leigh
    +109
    I have the ps2 running through component and didnt think much of the quality at all myself :thumbsdow but ive got a soft modded Xbox that has 720 etc: enabled and get a really crisp picture through component...
    My 360 obviously looked the best quality from what i remember being 12 days ago when it died and still no call about it repaired yet !:boring:
  7. dbm001
    dbm001
    Sep 20, 2004
    579
    28
    Manchester
    +47
    I have the same tv (32WLT58). The 360 looks sweet through component, there are framerate problems when using a vga cable so stick to component.
    I also have a modded xbox which looks great through component, especially with 720p enabled games. If you xbox is not modded go with a good scart cable.
    I have both scart and component cables for my Gamecube, both give a very similar picture.
    Haven't tried my PS2 on my tv, as it's been collecting dust for tha past 12 months or so....:devil:
    Dave.
  8. Lobo Soulman
    Lobo Soulman
    How is the 32wlt58 with the 360 then?
    I have just found out there is a 32wlt66 just been released which is meant to be better and cheaper!!!.
  9. DarkEntity
    DarkEntity
    Feb 13, 2005
    2,576
    2
    137
    Glasgow
    +597
    I have my old xbox running 720p output to my HD TV :)
  10. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Sorry but that is not strictly true. The UK Gamecube can output HD but the UK games don't. If you use a Freeloader to play US or Japanese games on a UK Gamecube you will get HD output.
  11. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    PS2 games that support prog scan look SO much better than those that don't. Just comapre NTSC Tekken 5 to PAL Tekken 5 to see the obvious difference! Which is why 98% of my PS2 games are US imports! As for Xbox, same goes really, but not many gmes support 720p there (only 1 I can think of, and a few support 1080i as well).
    So go for the new LCD and enjoy! :thumbsup:
  12. markmitt
    markmitt
    Oct 11, 2005
    1,153
    Huntingdon
    +27
    No you don't. You'll get 480p with games that support it. Better than normal, but clearly not HD...
  13. NackNack
    NackNack
    Aug 28, 2005
    3,562
    68
    Northampton
    +97
    Just prog scan. :)
