HDTV via Component?
Discussion in 'LCD & LED LCD TVs' started by Steviemacca, Jan 4, 2005.
  1. Steviemacca
    Steviemacca
    Don't know anything about these things. Is it possible to get HDTV via component? If the answer is yes, is it likely to be possible to get the copy protected service from SKY in this way?
    Any help really appreciated.
    Can anyone advise me on what if any LCDs out are futureproof to use the new Sky Service and are under £1100. Bigger the better.
    Steviemacca
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,110
    Manchester
    +713
    I doubt it. Copy protected content will probably be outputted at low (SD)resolution if there are component outputs available on the STB at all.
    Chris Muriel, Manchester
  3. Rob20
    Rob20
    Jul 3, 2004
    2,619
    103
    +354
    The 32" WL48Tosh has HDMI and component for around £1,000-1,200 ish.
