HDTV UpConverter
Discussion in 'LCD & LED LCD TVs' started by mjfe, Jan 11, 2005.
  1. mjfe
    mjfe
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Seems a bit on the cheap side. With cheaper stuff you can get problems with insufficient contrast range due to cheap a/d convertors. You need a lot of memory in the box to do the job properly.
    P.S. Although it's not mentioned in the spec, I suspect that this unit only handles 60Hz signals.
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Does it handle Pal?
  4. mjfe
    mjfe
    I found "HDTV UpConverter", when I ordered Sharp LC26GA3E yesterdeay/
    www.verkkokauppa.com.
    I dont know more.
    It is interesting, because HDTV so actual is.
    Martti
