HDTV samples
Discussion in 'TVs' started by geewhizz, Mar 30, 2005.
  1. geewhizz
    geewhizz
    Jan 2, 2005
    2,407
    +84
  2. quig
    quig
    Jan 17, 2004
    20
    We may or may not get the quality of the WMV-HD clips you downloaded from Sky's HDTV service. It will depend on the quality of the sources used, and the bitrates used for transmissions. The treatment of Sky One doesn't give us much hope, nor do Fox's 720p broadcasts (eventually!) in the US, which received criticism for their low bitrates. Note also that many of those clips were from IMAX sources, which will be higher quality than most, if not all, source material broadcast on Sky.
    However, it is also possible that the bitrates used will be reasonable. After all, Sky's existing premium channels are transmitted at higher bitrates than standard channels. As the service will be sold on its picture quality, Sky will surely have an incentive to use decent bitrates for the service.
    The real answer is we don't know, as there have not yet been any transmissions. Ask Sky themselves if you're interested in high quality broadcasts! However, it is important to mention that if the resolution of your display is 852x480, you are not even seeing the full vertical resolution of PAL. Although you will benefit from the small increase in horizontal resolution of 720p on your display, the increase in picture quality as seen on your display may be due to higher quality source material and/or high bitrates, rather than the increase in resolution of HDTV.
  3. barongreenback
    barongreenback
    Mar 30, 2005
    980
    +60
    It is possible to write those samples to a CD/DVD to test on my system?
  4. peahead
    peahead
    Dec 14, 2002
    2,847
    St.helens
    +285
    Hi give these divx high definition video clips a wurl they look brilliant and are not as big to download.
    http://www.divx.com/hd/ :hiya:
  5. geewhizz
    geewhizz
    Jan 2, 2005
    2,407
    +84
    Yip i used nero 6 to burn them to a dvd ( although it took 3 hrs ) :thumbsup:
  6. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    So you had NERO convert a wmv/vc9 encoded HD spec video stream to a mpeg2 coded video at DVD spec to demo HD?
    Interesting:)
    Few minutes later.........
    Just had a thought, you may have a divx DVD player so converted it to that format at the same resolution:)
  7. pm103672
    pm103672
    Just downloaded one of the clips. Looks AWESOME!! :)
  8. mjr600
    mjr600
  9. Leerock
    Leerock
    Dec 26, 2004
    273
    19
    Standard Divx players can t play HD divx neither wmv/hd.
    The best you can do is to use canopus procoder to convert wmvhd to mpeg2 at the maximum bitrate (9700) but at lower resolution 720x576 so it can play on your standard dvd player.
    I can tell you for sure that with such a high bitrate you DO NOT loose much detail, even with an SD resolution.
    I ve tried playing these with my pio dv575 on my pio 435HDE and i m very impressed with the results. :smashin:
    The picture quality you get is ASTONISHING :eek:
  10. cmt
    cmt
    Apr 4, 2005
    3,476
    +221
