HDTV - Phillips 32PF9986?
Discussion in 'LCD & LED LCD TVs' started by Londoner, Mar 25, 2005.
  1. Londoner
    Londoner
    I am looking at making the investment in a 32 LCD TV (32'' because I live in a cottage so space considerations mean can't look at anything bigger) which supports HDTV (in view of sky's launch of HDTV programming in 2006). :lease: I am looking at the Phillips 32PF9986 as it seems to be the best HDTV compliant 32'' LCD tv around at the moment. Would be interested in a) anyones views on the Phillips 32PF9986 - particularly from those who have it - and b) any other suggestions/better options in 32'' LCD tv's for HDTV.
  2. oldguy
    oldguy
    Feb 21, 2005
    42
    rotherham
    I was in same position 2 weeks ago - then I read the 9986 appreciation thread - all you may need to know !!
  3. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    You'll find tons of information on the 9986 in these forums! It is probably the most discussed LCD here.
    In short, yes, it is the best LCD currently easily available and will provide you with sensational picture quality and introduce you to a whole new viewing experience!
    So there.
    Jimmy
  4. imh
    imh
    Loewe are releasing a new 32 inch model for the same price (or cheaper) than the 9986 in a month or so. Will have HDMI and component connections, whereas the 9986 can only manage one at a time. If you can't wait though, the Philips is probably best for TV at the moment.
