HDTV over a LAN
Discussion in 'General TV Discussions Forum' started by jamesrich, Jun 7, 2004.
  1. jamesrich
    jamesrich
    Oct 15, 2002
    111
    +3
    I am having trouble watching these WM9 movies over my LAN; they stutter very bad, though locally they are fine. I have an AMD 2800+ (166 bus, 333 RAM) even though I am running at 100/Full Duplex from both PCs.
    Is this because my cheap SMC 1211 LAN card sucks processor time away from WMP?
    Has anyone come across this one, if this is the case can anyone reccomend a cheap NIC that is more independant of the CPU? :lease:
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,215
    83
    Over the Hill & Far Away
    +136
    Found that streaming any movie type files over the lan does not really work.. though xvid files (350mb) did work ok and that was on a wireless g link on my network. HD/WM9 are just too bulky and processor intensive I think for it to work well.
    Matt
  3. kunwho
    kunwho
    My house is wired with CAT5 cables all routed to a Scan 16port 10\100 router. I use my motherboard network ports and have no problem with the HDTV via LAN.
    I wouldn't trust wireless lan as the I think you need at least 6mbps stream to play 1080i HDTV signal.
  4. Deron
    Deron
    Sep 11, 2002
    366
    +12
    I'm hoping to try it when the new Kiss players come out...
    Hopefully streaming over a wireless g network should be acceptable.
    Failing that I'll go for the hdd version...
  5. jamesrich
    jamesrich
    Oct 15, 2002
    111
    +3
    I'm not using a wireless LAN. Which LAN chip do you use on your motherboard, and what processor do you have installed. Thanks
  6. db1234
    db1234
    Oct 18, 2002
    460
    I have no problems streaming HD material from an old P3 to a 2.4 GIG P4, both using onboard NICs.
    Try setting both NICs to half duplex, full duplex can cause all sorts of funny problems...
    Cheers,
    Darren
  7. jamesrich
    jamesrich
    Oct 15, 2002
    111
    +3
    Fixed it, upgraded to latest SMC 1255 NIC drivers.
    You can close the thread mods.
