hdtv only one hdmi input
Discussion in 'Televisions' started by christhedon, Sep 4, 2005.
  1. christhedon
    christhedon
    Jun 23, 2004
    482
    +4
    Can you get splitters for hdmi inputs like the scart splitters you can get?
    If your TV only has one HDMI input and you have two hdmi sources what are the options to get them both working on HDMI?
    Thanks,
    Chris
  2. TheDoctor
    TheDoctor
    Aug 31, 2004
    389
    28
    +42
    Hi Chris
    It is possible to get HDMI switchers but they are expensive. Keene Electronics sell one for £280 and you will only get one extra HDMI input (from 1 to 2). But it does come with a remote to switch the inputs and both inputs will be HDCP compliant. They call it the "HDMI switchbox".
    All the best
    Doc
  3. Shakey_Jake33
    Shakey_Jake33
    Unless you have 2 HDMI devices already, and plugging them into the DVI is a no-go, then you should hold on to your cash. When HDTV becomes more mainstream, I'd imagine prices would become more sensible.
  4. kourosh
    kourosh
    Feb 6, 2005
    13,834
    Portsmouth
    +907
    depending on your equipment you can daisy chain them my tv and dvd player has only 1 but my amp has 2 hdmi 1 in and 1 out so im able to connect my dvd to amp via hdmi which does both picture and sound and then connect amp to tv :thumbsup:
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    23,802
    The Borders
    +2,470
    christthedon
    There are lots of HDMI and DVI (with HDCP) switching and distribution products already on the market.
    You can have anything from 2:1 through to 8:1 switchers and 2:2 through to 2:6 Distribution switchers.
    Some HDMI switchers are Digital Video only - others offer Digital Video with Digital Audio (on an Optical Output) and the latest units offer full spec HDMI+Stereo or Multi-channel audio on HDMI connectors.
    A Gefen 2:1 (Digital Video Only) HDMI switcher will cost you approx £175.00.
    Best regards
    Joe
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    It looks like these two products have now been officially announced so I will post the link to them here.
    Meridian have produced two products, one a HDMI extender allowing HDMI cable runs of up to 50m and a 4 to 1 switcher that also includes the extender technology. Both carry video up to 1080p and multi channel audio. The extender technology in both units corrects signal defects from –20dB to +6dB and improves image quality and stability, reduces noise and jitter on both short and long cable runs.
    Full integration to Meridian systems via 500/G series comms is ensured plus RS232, IR and manual switching for non meridian systems. Prices yet to be announced although I am sure that they will be at CEDIA in a few days time.
    -Ian
  7. mjbtin
    mjbtin
    Jan 13, 2005
    2,056
    83
    +383
    The new range of Sagem dlps have two hdmi inputs,so if you are thinking of getting a large rp dlp and plan on getting Sky hd and an hd player maybe worth considering
  8. banditash
    banditash
    Dec 24, 2001
    38
    Lancs
    You can have a look on here for HDMI splitterhttp://www.dtrovision.com/index.htms
  9. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    What do you need 2 HDMI conenctions for ? I can only think of DVD players that have HDMI or are you thinking of future proofing ?
    Richie.
  10. loz
    loz
    Jun 4, 2001
    13,058
    +1,796
    In the very near future.
    Sky HD box
    Playstation 3
  11. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    I suppose you could use a HDMI to DVI jobby if you have DVI too, i'm assume that would be ok, then you could just connect the PS3 to an amp with via optical
  12. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
    I can recommend this companyAVLink-Electronics in 4 days i recieved a 1:4 Dvi switch box.It cost around £215 delivered,it included 4 pretty good quality dvi-dvi leads
  13. mediamogul
    mediamogul
    Jan 25, 2002
    490
    Chatham,Kent
    +18
    http://stores.ebay.co.uk/AVLink-Electronics_W0QQssPageNameZviQ3asibQ3astoreviewQQtZkm[/URL] Sorry link didnt work
