HDTV on the Mac in 5 min
Discussion in 'General TV Discussions Forum' started by mine, May 16, 2004.
  1. mine
    mine
    Feb 8, 2004
    128
    19
    88512 Mengen Germany
    setup
    eytv 300 DVB > Firewire > G5 or G4 > 1,2 GHz (HDTV) G4> TV
    install software- station scanning - take remote control -
    switch to euro 1080 - bingo
    some small additional benefits :
    fully digital - no A/D conversion with TFTs - time shifting- HD recording-
    programming vs. web - automatic conversion from TS stream to QTime
    MPEG cut with preview pics- seemless integration with Toast - 5 mouseclicks > DVD
    300 Euros here in Germany
    by the makers of Toast and the former Astarte guys
  2. jont
    jont
    Apr 8, 2002
    4,289
    near Aylesbury
    +556
    will that work off one lnb feed from a quad lnb on a sky digital facing dish ?
  3. Kramer
    Kramer
    Nope, different position from Sky digital - see other threads for details :thumbsup:
  4. jont
    jont
    Apr 8, 2002
    4,289
    near Aylesbury
    +556
    if I get an lnb arm with 2 lnb's on it can they be positioned to pick up off the same dish ?? thought sky & euro was off astra 19.2e ?
    OK ... did more specific search and got answer ... yes !!
    Anyone recommend a good CAI installer in or around Glasgow ?
    cheers
    Jon
  5. digitalsafari
    digitalsafari
    Jul 23, 2002
    728
    46
    Devon
    +123
    Jon,
    The small flaw in your plans is the Mac Sat receiver is Free To Air only and does not have a CI slot so you can't view Euro1080 as it is now encrypted.
    Jonathan.
  6. jont
    jont
    Apr 8, 2002
    4,289
    near Aylesbury
    +556
    Ahh ... there goes that idea then ... :-(
  7. mine
    mine
    Feb 8, 2004
    128
    19
    no ..not at all
    eyetv version available with ci slot -> alphacrypt > euro 1080 card
  8. jon2099
    jon2099
    Jun 4, 2003
    183
    Hampshire
    +4
    mine, does that mean a 1.2GHz G4 (such as the one in the Mac Mini) can decode 1080i MPEG-2 files real-time? There was a review on a website (I think it was Anandtech) that said the Mac Mini could not decode MPEG-2 TS files higher than about 13MBps bit-rate. They were using VideoLAN client as the decoder though.
  9. mine
    mine
    Feb 8, 2004
    128
    19
    yes..
    a mini mac with the eyetv player is able to decode 25 fr. of a18 Mbit
    1080i ts stream- this is rather a sensation..
    This is why...:
    the main problems here is that apple actually doesn`t allow access to the hardware acceleration of the graphic card (access is limited to apples own dvd player ).
    so this has to be done in software alone , assisted by the quartz engine .
    vlc and the QTplayer have more overhead than the rather optimized eyetvplayer.
    ....b.t.w made by dr.markus fest ( toast - astarte a.o.)
    on the PC side , you need a 2,8 GHz P4 or a similar AMD cpu to decode a 18 MBit HDTV stream
    without DXVA acc.
    regards from black forest germany
    mine
  10. jont
    jont
    Apr 8, 2002
    4,289
    near Aylesbury
    +556
    so will the h.264 QT codec in OSX 'Tiger' help it perform a native HD decode more efficiently than that ?
  11. mine
    mine
    Feb 8, 2004
    128
    19
    hi jont
    for sure ... but like often better decoding .. better hardware
    same on the wintel platform - if you use the wmv 9 hd codec the hardware requirements for 1080 p are > .... 3 GHz CPU
    the G 5 does (per se ) a fantastic job with encoding and decoding tasks ...
  12. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,905
    68
    +49
    Would the new ibook with it's 1.2ghz CPU and 256MB decode Euro1080 etc ?
  13. mine
    mine
    Feb 8, 2004
    128
    19
    as there is a similar architecture (compared to a minimac) its possible , but as long as apple hesitates to improve accesss to the hardware acceleration of the nVidia and ati graphic chips for third party softwareplayer developers you pretty much need a perfect configurated device.
    but....cupertino finally knows that there are strange things like htpcs and so there is hope on the horizon..... :)
    @ Cebit 2005 german telekom for the first time showcased their own little htpc..
    30 apple G5 2,5 and 90 50 " Plamas ..... an impressive videowall
    regards
    mine
