HDTV on an old Sky dish ?
Discussion in 'General TV Discussions Forum' started by triplebj, Nov 20, 2003.
  1. triplebj
    triplebj
    Pardon the possibly stoopid question :)
    The previous owner at my place left a Sky dish on the wall (but took the box !). Can I use this dish to feed a SkyStar 2 card just to cheaply check out what HDTV looks like ?
    I understand that the dish will have to be repositioned a few degrees ?
    TIA,
    /BJ
  2. rigman
    rigman
    Dec 14, 2000
    2,884
    83
    East Yorkshire
    +83
    If it is the 45cm oval shaped one that is used for sky digital then the answer will be No. You will need one slightly larger. If it is the analogue dish then the answer is yes as these were 60cm.
    Darren
  3. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    Also if it is the analog dish it will probably be pointing at 19.2 E.
    Double bonus.
    Jim
  4. triplebj
    triplebj
    Thanks, guys !
    Sounds like I will have to go home and measure it......
    Anything else to look for ? Or is it all in the size (ahem :) )
    /BJ
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Silly question but will a sky analogue dish and LNB connected to a Sky digibox get any channels?
  6. Kramer
    Kramer
    If it's an analogue LNB, no.
    Digital LNB yes but you need to input frequencies etc. in the "other channels" menu of the digibox.
    Lyngsat will have details of (free) available channels @ Astra 19.2.
  7. Bluelaser
    Bluelaser
    You can get astra 19.2, but very rarely from a 45cm minidish. A professional aligner and a sunny cloudless day and good place in the uk is essential though.
