HDTV Help
Discussion in 'General TV Discussions Forum' started by WeSayAJ, Apr 23, 2007.
  1. WeSayAJ
    WeSayAJ
    Apr 23, 2007
    16
    Hey,
    I was pointed here by a couple of chaps from another forum. I am looking at getting a HDTV, problem is after some research they seem to be ridiculously complicated and a real minefield. :(
    I dont want to get a piece of crap and I have some fairly specific needs and wants for it so hopefully you guys will be able to lend a hand.
    Okay for the most part I plainy need a new TV my old one is seriously dated and not HD Compatible. I want a 1080p set because i have recently bought a PS3 and when the stunning 1080p games come out I want to see them in all their glory. I have heard that you cant get 1080p on anything less than a 42inch and also that its dodgy getting a 1080p with anything less than 1920 x 1080 pixels. Apparently if its not this setting then scaling down to a standard defintion can look really bad. Im looking at around a grand as a budget but obviously the cheaper the better!
    So in short
    Requirements
    HDTV
    1080p not 1080i
    42inch plus
    Decent make
    1920 x 1080 pixels
    £1000 budget
    Wall mountable (no need for stands or flashy surrounds which should keep the price down to an extent i assume its cheaper to have just the set and wall mounts going by the varying prices on the TH42PX70)
    Questions
    Can you get 1080p on smaller than a 42'?
    Is the pixel requirement true?
    Do I need to know anything before jumping both feet first?
    Plasma vs LCD - Whats better? Somebody told me that Plasmas burn out after a few years? Surely thats not true?
    Just require some advice tbh guys as I have no real idea and I dont want to make a massive cock up!!!!
    Thanks in advance :)
  2. alphaomega16
    alphaomega16
    May 17, 2005
    14,121
    163
    Southend on sea
    +3,761
