HDTV Future Planning
Discussion in 'Plasma TVs' started by Corazonis, Apr 10, 2005.
  1. Corazonis
    Corazonis
    A simple question and hopefully a set of simple answers required.
    Having been looking at HDTV requirements and specifications for some time, I want to buy a new Plasma and possibly a scaler of some sort to fill any gaps.
    My requirements - at least 50" size, resolution enough to handle 1080 x 1920 (and all sensible HD modes for reasonable future proofing) and no sound requirements on the screen.
    I'm going to be watching Sky (probably going to their HDTV offering - boo hiss), DVD (haven't got a new DVD yet as I want to see what happens to Blu-Ray and HD DVD first) and PC/XBOX Inputs (DVI for PC).
    So, the question is, what's the best combination?
    Don't need justification unless I've asked for something impractical/irrelevant, just suggestions.
    I guess that wasn't as simple as I first thought :rolleyes:
    :smashin:
    C
  2. Sprout Crumble
    Sprout Crumble
    Dec 26, 2001
    228
    +5
    No plasma will do native 1920x1080, only the 45" Sharp LCD (dearer than a 50" plasma unfortunately). All will scale unencrypted Hidef internally although only a couple are ready for the Sky encrypted stuff (Pioneer 505, NEC 50XM4?, Panasonic 500 series)
  3. dilsher
    dilsher
    check my signature if you want one of the very best hi end options at present. But at a price.
    Dil
  4. NicolasB
    NicolasB
    Oct 3, 2002
    6,070
    Emily's Shop
    +669
    Not that much dearer, actually, you can get it for £4800 online.
