Hi Everyone,
I need some advice for a Philips 42PF7520D HDTV i have which unfortunatelly doesn't have HDMI and only one DVI and 3.5mm audio input. I have a Xbox 360 with HDMI and a Shuttle PC with DVI connectors which i want to connect to the TV.
I understand i need a switch to put these together and found something like this
2 Port DVI-D Switch with Audio: Amazon.co.uk: Electronics & Photo
but i would like to know if there is any automatic switchers available. The one above also seemed quite cheap, does that mean they don't necessary hit DVI/HD standards? I don't think there is any point in buying HD and bolting on a cheap switcher but at the same time i don't want to spend more when the cheaper alternative will be just as good.
Also am i missing anything? I've already got an adapters for the Xbox (HDMI to DVI) and RCA to 3.5mm.
Any advice or ideas would be great.
Thanks in advance.
Chris.
Thanks in advance.
Chris.
