HDTV and Panasonic TH42 PW4
Discussion in 'Plasma TVs' started by marky1975, Aug 26, 2005.
  1. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    can anyone tell me if my panasonic PW4 is compatible with HDTV
    as a few reports have said yes and some no
    then some say you can watch Hi-def on it but not at Hi-def quality.
    apparently i can get a dvi component board to slot in the bottom but have never sen one for sale.
    can any one let me know
    Mark
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,797
    Norwich
    +673
    You can hook Sky up with component and get all the resolutions, it will down scale to 480lines as that is the resolution of your screen, but don't worry it will look stunning and far better than some so called "HD-READY" screens that are out there.
    If at a later date they only allow PPV films etc. to go out on the HDMI connector, you would need a converter to strip the hdcp and allow you to go in on the vga input. But worry about that in a couple of years.
  3. Piers
    Piers
    Dec 11, 2002
    1,973
    Shropshire
    +227
    The PW4 is a standard def panel so it doesn't have enough pixels to display a high def picture. Fed component video from the upcoming Sky HD box it should give a picture, and probably a better picture than current sources but it won't be high def.
    The DVI board won't help.
  4. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    thanks very much to you both for the info.
    I have it wired up component from sky now via my denon avr 2105
    so it will show hi-def pics but and be better then normal pics but wont be true Hi-Def is that right
    Mark
  5. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,797
    Norwich
    +673
    Hi-Def is not just about resolution, it plays a big part in it but there is so much more.
    Pal tv is broadcast at 720x576i
    Pal DVD is also at 720x576i
    However a DVD of the same film shown on TV can look quite a bit better, and the same goes for the other way round.
    You will be impressed with HD even on an SD screen.
