HDTV: 720 or 1080
Discussion in 'Xbox Forums' started by nigel2shady, Dec 30, 2006.
  1. nigel2shady
    nigel2shady
    Jun 4, 2006
    734
    +9
    I bought a 360 this week,and looks stunning on my Sony HDTV just beinterested to see wot setting you put your display to,I have myne at 1080 and dont see any difference from the 720 setting...So be interested to see wot setttings you have your at...Also is there really a big difference from the 1080 to the normal tv setting off 400..
  2. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    1080i or 1080p?
    What's the native resolution of your TV? If it supports 1920x1080 then 1080p is the way to go, if it's 1366x768 then choose 720p.
    Out of interest, would you call Wotsits (crisps), Whatsits? ;)
  3. nigel2shady
    nigel2shady
    Jun 4, 2006
    734
    +9
    Wotsits every time lol I have myne set to 1080i i think...
  4. GaryMo
    GaryMo
    Dec 18, 2005
    3,620
    Nr Manchester
    +280
    Its just a case of trying both 720p and 1080i and see which you prefer.
  5. ukkev2000
    ukkev2000
    Apr 12, 2004
    1,027
    48
    Hampshire
    +51
    Simple - for games, set to 720p
    IF and ONLY IF your HDTV has a big enough panel resolution for 1080, AND you are watching HD-DVD (via VGA, then set it to 1080p/via component, 1080i)
    American TV is 480i, PAL/Europe is 576i, Shop DVD's playback at 576p on the XBOX360.
    I hope this is enough information to confuse you!
    If it isn't, myne= "mine"
    and "off 400" probably should have been "of 480"
