sonysean
Established Member
Apologies if this isn't the best section for this question (it covers a few devices and I'm not sure which is the main issue).
I've not long had an LG B9 and Denon AVRX2600H set up and mostly everything has worked fine with no problem, except a couple of little problems which I'm not sure the cause of.
The main annoyance is my PS4 (original model) seems to occasionally "forget" it's HDR settings.
By this I mean some times when launching a HDR supported game, I will get the PS4's HDR settings come up like it's the first time HDR has been enabled, and I have to adjust the brightness settings.
This doesn't happen every time, which makes it stranger.
Also I've noticed while playing a HDR game, if a PS4 notification comes through (like a trophy or taking a screenshot), the sound cuts out for about a second.
I thought the issue could be perhaps I'm using an older version HDMI cable between the Denon and the PS4 but I can't see that being the issue as I believe you need a HDMI 2.0+ cable for HDR to work in the first place so I can't see how that would be the problem as it does work.
Edit: I fixed the Blu-ray player issue by connecting it to LAN and updating it to the latest firmware released back in 2014
