HDR from jpegs?
Discussion in 'Photography Forums' started by braiden, May 1, 2007.
  1. braiden
    braiden
    Feb 9, 2005
    680
    +46
    Hi Guys and gals
    Does anyone know if it is possible to adjust the exposure for photo's shot in jpeg format, in PS?
    Got a few old photo's that I would like to experiment with in photomatix. Would appreciate any advice or suggestions.
    :thumbsup:
  2. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    It is possible to change the exposure of a jpg in CS2. If you go to Image > Adjustments > Exposure.... you will have a slider that you can adjust the exposure via. It doesn't work brilliantly and certainly not as well as you would be able be able to do with a RAW. No idea how well it would work with Photomatix - I guess you should just give it a go and see if it works.
  3. braiden
    braiden
    Feb 9, 2005
    680
    +46
    Thanks electrolyte, sorted now:smashin:
  4. braiden
    braiden
    Feb 9, 2005
    680
    +46
    Well did some HDR in Photomatix with Jpegs, here's the result what do you think?
    [​IMG]
    [​IMG]
    You can see the full size ones on my flickr.
    Advice and constructive criticisms always welcome
  5. ScottBT
    ScottBT
    Jun 12, 2006
    967
    East Kilbride, Scotland
    +47
    I made this HDR from 1 Jpeg:
    [​IMG]
    1.5EV either way and then tone mapping. Not as good as 3 images and I got a bit excited during the processing but I think it works well.:)
  6. braiden
    braiden
    Feb 9, 2005
    680
    +46
    It certainly looks good to me :thumbsup:, I adjusted the exposure 2.00EV either way on each jpeg used in the two above shots.
  7. electrolyte
    electrolyte
    Feb 3, 2002
    4,030
    Sheffield
    +1,045
    @ Braiden - Those have worked well mate. I remember seeing the originals in another thread and thought they were a little dark. The HDR versions are much better and I can now make out much more detail. I really like the perspective of the path on the Big Ben shot.
  8. braiden
    braiden
    Feb 9, 2005
    680
    +46
    Thanks electrolyte, I think they look better than the originals too. As you say there is a lot more detail in them now and the colours also look much better.
