Hdmi
Discussion in 'Xbox Forums' started by ukbootlegs, Feb 1, 2009.
  1. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    Gave my mate a HDMI cable for his 360, but it didn't carry any audio.
    Anyone know what the issue could be?
  2. noluv6
    noluv6
    Feb 1, 2009
    43
    Birmingham
    seen this a few time's and i'm sure it is the update that causes it "well thats what ive been reading".
    google it,say hdmi sound not working on xbox 360 and i'm sure you will get plenty pop up as i've seen this atleast 5 time's on xbox.com,just to note mine work's fine
  3. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    How do u mean no audio?
    I assume you mean he's connected his xbox to his tv and its not working through the surround sound system/amp? Or no audio through tv either?
    if its the surround sound problem see this post:
    http://www.avforums.com/forums/1889579-post4.html
  4. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    No audio through the tv
    He doesn't have a separate amp.
  5. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    Real guitars don't have strings, they have 5 colou
    +934
    I'm willing to wager it is a Samsung TV.
    It's a known issue with the NXE, the only fix is something that I don't want to post as I can't advise it, but searching online if you really want to will give you the solution.
    The only real solution is start using component or VGA
  6. p9ul
    p9ul
    Jul 29, 2004
    8,837
    +780
    Was just about to post the same thing.
    In all honestly - the difference between Component & HDMI is minimal, unless you're upscaling to 1080p then I switch to component and get your audio back. Not an ideal solution I can appreciate... (I hate having stuff not working properly).
  7. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    +934
    I'm back to Component at the moment (1080p), while my HDMI console is waiting for repair. No difference at all really, slightly darker picture but that is corrected by a slight adjustment of the settings.
