hdmi??????
Discussion in 'Cables & Switches' started by jonnyseale, Jun 28, 2005.
  1. jonnyseale
    jonnyseale
    hello everyone not sure if this is the right forum bu ti wondered if there is a way of distributing hdmi over cat 5 cable for long runs or if indeed hdmi can be run between 10 and 15 meters without signal loss thanks :hiya:
  2. loadsofleads
    loadsofleads
    Supra have the HF100 DVI/HDMI cable which is designed for longer runs. 20 meter is the recommended limit for DVI but HDMI can be a lot longer, can't help you with CAT5 though :thumbsup:
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,760
    The Borders
    +3,088
    jonnyseale
    There's no need to go to CAT5 for HDMI when your only going to 15m - our BetterCables Display Magic HDMI cables are available in lengths including 12, 15, 23 and 31m.
    We use/supply Gefen (and AutoPATCH) HDMI and DVI over CAT5 converters and whilst it has its place its a lot of unnecessary cost at these 'short' distances.
    The Display Magic cables are good for 1080P at the lengths indicated so more than adequate for any Home Theatre application.
    If you need 'Distribution' we also have Gefen 2x2, 4x2 and 6x2 HDMI Distribution Amps on the way.
    Best regards
    Joe
