Hi guys,
I ran 25mm conduit through the entire house during renovation and now trying to find an HDMI cable that will fit through it. I believe the internal diameter is 21-22mm.
Standard cheapo cables with semi bulky ends do go down the conduit but not through the 90 degree bends (2) , which makes me believe that cables with detachable ends will have no problems at all.
I ran into a couple such cables so far (supra, kordz prs, monster HDS) but they are wildly expensive. Ideally i would like to future proof the 10m run (for high bandwidth 4k) but if i find something cheap enough i don't mind re-doing it in a couple of years.
Anyone got any suggestions in mind apart from HDMI over ethernet? As a worse case scenario i prefer to spend more on an expensive long cable that fits rather than introduce more failure points, complexity and compatibility issues with them extenders.
