LittleGreyCat
Now in the good old days if you didn't have an appropriate tuner in your video recorder IIRC you could feed a signal from your TV SCART to the video recorder.
Just looked at my Panny and it shows AV In/AV Out (presumably composite video) for the SCART sockets.
So can you do the same with HDMI?
i.e. take a signal from the TV via HDMI into for example a PC with an HDMI port?
Or are all HDMI ports push or pull only?
Just trying to work out how I can record with my HTPC before I get tuner cards.
LGC
LGC
