HDMI video / audio splitter
Nickffc
Hi all
just about to purchase my first PJ but i have a small problem....
i need to split the audio from the video from my source (PS3) before it gets to the PJ....
i know the ideal situtation is to put the HDMI through a AV amp with HDMI in's and out's but i dont have one of those yet.... so in the mean time i need to find some way of doing this
i've had a search around the tinternet but all i seem to come up with is HDMI splitters that just do audio and video together... like one in and two out....
any ideas?
Nick
any suggestions...?
madhouse
hi,
do you have surround sound? You can feed it with digital audio via the PS3 optical out and then just set the PS3 to use HDMI for video and optical for sound?
Simon
Nickffc
unfortunately no digital audio in.... just phono's
Nick
Joe Fernand
AVForums Sponsor
It is possible to Install a 1x2 HDMI Splitter that also separates out the 2 channel Stereo audio from the HDMI signal - Media Factory - Octava HDDA12A-UK, HDMI1x2 Distribution Amp + audio converter
If you don’t require to drive two Display devices (Display + New Projector) you don’t require any electronics if all you require is Video to the New Projector + stereo audio to your Hi-Fi Amp – simply install the HDMI cable plus the standard PS3 ‘AV’ cable.
Set the PS3 to the required Video resolution (via HDMI) + enable ‘Dual’ Audio out and set AV Audio Out to On – connect the Red/White RCA of the AV cable to any Input on your Hi-Fi Amp (apart from Phono).
Joe
Nickffc
Thanks Joe
very good idea..... then i looked at the price...wow....!!!
i was hoping too do this on a very tight budget but i suppose quality comes at a cost.
i may as well dip a toe into a better AV amp like this...only £20 more...
Onkyo TXSR309 Black | AV Receiver | Richer Sounds
cheers :smashin:
Nick
Joe Fernand
AVForums Sponsor
The AVR may be a good option - depends on the quality of your current Hi-Fi 'Stereo' Amp.
Whilst AVR's have all the technological bells and whistles for use in a Surround Sound system they are often lacking in the sound dept when compared to a decent Hi-Fi amp for two channel use!
Joe
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
