Wswan85
Established Member
Evening all,
Just wondering if anyone has any experience with a HDMI transmitter? If so which type and how exactly did it work? Are they a waste of money? Seems like a good way to set a projector up in an already decorated area.
I see there are various types online, some quite expensive. They claim they can transmit upto 1080p HD and even 3D signals over various distances in-room.
I have the usual situation - a projector on the rear wall behind the seating position with a screen on the front wall in front of the TV when in use. Only talking a distance of circa 3m but to run a HDMI cable round the room is tricky and would have to be very long. So at the moment when I want to use the projector I have to run a cable across the middle of the room - not ideal with kids! And has to be plugged in every time.
I only have a 1080p projector for now, use it with SkyQ & blu ray player mostly, all running from a Denon AVR X2300w with dual outputs. When I eventually redecorate I'll run the cables properly and upgrade to a 4k projector but that'll be a while away unfortunately .
Thanks for any help.
Will
Will
