HDMI to VGA?
Discussion in 'Plasma TVs' started by macbandit, Jan 18, 2005.
  1. macbandit
    macbandit
    Is there a way to convert a HDMI to a VGA signal? I'm having problems connecting my computer to my panny plasma through DVI on my computer but it works fine on the front VGA ports. I want to hide the cables and there is no VGA on the back so I wonder if the HDMI port is an option.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,598
    3
    North Yorkshire
    +282
    DVI from a computer to an HDMI input should be fine if you have an output resolution such as 1280x720 @60Hz, which is the same as an HDTV resolution. Btw, converting an HDMI input to a VGA output would be against licensing rules for the manufacturer of such a device. Hope this helps.
    Steve
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    i think an IscanHD+ will convert VGA up to digital for HDMI.................Lumagen may do this too.........
