Smeeble
Established Member
Hi.
I've got all my AV gear setup in one room, but need a 1080p signal (at max) to be sent into another room.
I can't get under the floor etc to run cat 6 cables, so the obvious option is void unless there's any brilliant ideas to run it.
I do have twin basic sky coax running from one room to the other, so had thought about HDMI over coax. Can't use them to pull other cables thorough as they are plastered into part of the wall.
I've also thought of HDMI over mains, and also wireless.
Anyone used anything other than cat cables, and have any recommendations?
If I use both coax I'd need it to have return IR, but if only one or another option I can do without.
Thanks.
Thanks.
