HDMI to DVI Cable
Discussion in 'Cables & Switches' started by Nitemare360, Jan 2, 2007.
  1. Nitemare360
    Nitemare360
    I just have a question. I have an HDTV but it only has a DVI connection, no HDMI. The question is, with a HDMI to DVI cable would I still get the same quality (1080i) on my TV with this cable as I would if my TV had an HDMI interface?
    Thanks.
  2. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
    up to 7m i would get a QED cable!
  3. JohnWH
    JohnWH
    Jan 23, 2004
    1,826
    48
    St Albans
    +82
    Assuming the DVI input on your TV is HDCP compliant the picture should be as good in a all practicallity, assuming you correctly calibrate the picture.
    You'd need to give the make and model of the TV to find out if the DVI input is HDCP compliant.
    Cheers,
    John.
