I am thinking of buying a Lumagen Vision HDQ and was just wondering if there are any issues with using hdmi to dvi cables into the lumagen and then DVI to HDMI cables from the lumagen into my plasma.
The DVI on my plasma doesn't support HDCP so i'm assuming that I would use the HDMI for input. Does the HDMI allow me to output at the panel's natural resolution or is that only via DVI.
My HDMI inputs are likely to be Sky-HD and Pixel Magic HD Mediabox for the foreseeable future with DVD player via component and XBOX 360 via component.
Would the XBOX 360 be better via VGA with some sort of VGA to DVI converter?
Sorry for so many questions, thanks in advance for you help.
