HDMI to BG 1209s - Picture not wide enough
Discussion in 'Projectors, Screens & Video Processors' started by Rittberg, Aug 4, 2006.
  1. Rittberg
    Rittberg
    Dec 11, 2002
    70
    Omer, Israel
    +6
    I connect the HDMI output from an Humax PR-HD 1000 STB ( HiDef receiver) > Moome’s device ( DVI/COMPONENT TO VGA TRANSCODER ) > BG 1209s port 5.
    The picture H size, even its set to 99% is not utilizing the all screen (I need another 20% in order to fill the screen).
    The H size problem appears at both HDMI output resolutions - 720P or 1080i. The V size is OK.
    BTW - No problem when connecting the DVI( via Moome’s device) or the VGA output from an HTPC to the PJ at any resolutions from 800 X 600 until 1920 X 1080.
    Any Idea how to increase the picture’s H size when using the Humax STB as the source.
    Thanks,
    Rittberg
  2. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    I'm guessing your refresh rate is 50Hz not 60Hz
  3. Rittberg
    Rittberg
    Dec 11, 2002
    70
    Omer, Israel
    +6
    From the Humax - 50 Hz.
  4. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    It's standard problem with HDMI timings. Stupid porches for 50Hz, whilst everything else, 60Hz and computer style res, is fine.
    There is a solution, but costs money: buy a HD scaler which can redo the timings to something sensible. Lumagen and Crystallio.
  5. Rittberg
    Rittberg
    Dec 11, 2002
    70
    Omer, Israel
    +6
    What about the P2 on the SMPS sub board ?
    Is it not dangerous when it is ok for the PC source ?
  6. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    Just read your last post. Sorry, don't understand....
  7. Rittberg
    Rittberg
    Dec 11, 2002
    70
    Omer, Israel
    +6
  8. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    It's not something I would do. The timings for 50Hz HD are clearly a complete cock-up and therein lies the problem, not with the PJ.
    The C2 scaler nails the problem perfectly, and I'm sure Lumagen could as well.
    Do you feel like throwing money at it?
  9. Rittberg
    Rittberg
    Dec 11, 2002
    70
    Omer, Israel
    +6
    Basically I am using an HTPC, I am waiting that the new DVS-S2 card will arrive, hopping to be able to watch fluently the HiDef MPEG4/H264 channels. In this case the H size will be solved.
