HDMI Switching box
peahead
Hi mate
I recently bought one of these new vivanco 4 in1 hdmi switch boxes.
it even has its own remote and has manual or automatic detection.
google it mate
MickB
I've just bought the Octava 3 into 1 HDMI switcher from Joe @ TMF, £120.
It comes with a remote, but is also fully automatic, with a sensor which switches to the input most recently 'enabled' via a signal.
Installed yesterday, plug & play, & works a treat!!
Joe Fernand
AVForums Sponsor
Hello Blue.Rocket
Octava have Three options you can consider:
HDS5-UK - 5x1 UK SRP 149.95 GBP
HDS32-UK - 3x2 UK SRP 199.95 GBP
HDS3-UK - 3x1 - UK SRP 119.95 GBP
All three have Automatic and Manual switching and all Three work with SKY HD - though you need to put SKY HD on Input 01 as its always 'communicating' with the switch; even when the SKY HD box is in standby.
See http://www.octavainc.com/
Best regards
Joe
Similar threads
