HDMI Switcher
Soulfinger
http://www.amazon.co.uk/s/ref=nb_ss...&field-keywords=vivo+hdmi&Go.x=0&Go.y=0&Go=Go
I'm looking to get it and it's got some decent specs for £49.99 like HDMI 1.3 and I like the HDMI ATC lab endorsement though at £49.99 it sounds to good to be true.
Product Features
* The only HDMI switch box to be approved by HDMI ATC lab
* Fully supports 1080P HDTV
* HDCP Compliant
* Supports DTS, Dolby 7.1 Channel Audio
* 21 HDMI source input
J80FAB
I'm not sure what they mean by Supports DTS, Dolby 7.1 Channel Audio in the spec listing when I was under the impression that HDMI cannot carry these signals just bog-standard PCM stereo :confused:
What does 16 HDMI source input mean :confused:
Have you seen this :
http://www.xtrememac.com/audio/av_cables/switcher/
An alternative I'm told is very good. You need to have a look at the specs to make sure :smashin:
cebs_uk
I think hdmi 1.3 allows for uncompressed pcm 24bit/96Hz 7.1 soundtracks as long as you have hdmi1.3 at both ends (player and receiver).
It is explained a bit in the latest issue of hcc in their review of the hd-xe1 but I think they could do with a new guide to specs for amps/plamas as each review these days seem to point out factors that are not mentioned on other similar products.
Cebs
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
