HDMI Switcher (part2)
Discussion in 'Cables & Switches' started by stickybz, Mar 25, 2006.
  1. stickybz
    stickybz
    Does anyone know where I can find a cheap HDMI switcher?
    Just repeating a question someone asked sometime ago (in the hope that more options are available now.) I'm looking to connect 2 or 3 HDMI sources to one (ie LCD) HDMI input.
    All Ive found so far is a £150 two way box from Maplin, but that seems a bit steep!
    Any help much appreciated.
  2. jackal
    jackal
    :) You won't find cheaper at the moment. Make sure whatever you buy is HDCP compliant.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,756
    The Borders
    +3,520
    Hello stickybz
    You need to be clear if the switcher your looking at is for Video only or Video + Audio and is the Audio to be carried forward on HDMI or on an Optical/Coaxial connector.
    Best regards
    Joe
  4. stickybz
    stickybz
    I only need video via HDMI to the LCD (audio will go straight to receiver).
