HDMI switch
Discussion in 'Playstation Forums' started by Ethan2000, Apr 23, 2007.
  1. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    I could do with one of these as SKY HD is now on component as the PS3 is using my one HDMI slot, this looks like a great price, and I was wondering if anyone has seen/bought one ?
    CLICKY
  2. ali35
    ali35
    Mar 13, 2006
    247
    2
    colchester
    +35
    I've just ordered one, someone on the cable section recomended it.
    Worth a try for 35 quid
  3. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    yeah fair one i will do the same.
  4. lennon
    lennon
    Oct 19, 2005
    226
    +6
    Got one on Friday. It seems to work ok although there are some wierd little quirks with it.
    It works perfectly with the PS3 but with SKY HD I have to switch SKY on and off a couple of times when the connection is selected for it to pick up the signal.
    Also when I left Sky on and then switched the TV off and then my partner switched sky off it seemed to muck up the HDMI signal from SKY as I had to reboot the sky box.
    This may be because I am running the power off the sky usb port though rather than the mains. Havent tried.
    Only two problems I have come across though other than that saves switching cables all the time!
  5. PhilNUK
    PhilNUK
    Dec 30, 2005
    881
    28
    +25
    just ordered one of these too... though after reading your post I am not as excited about getting it now.. .I have Sky HD, PS3 and upscaling DVD player, I will give it a try and see if there are any problems with mine.
  6. fid
    fid
    Jan 17, 2006
    600
    28
    Wigan
    +37
    have you tried running the hub of the ps3's usb port rather than the Sky
    I think that may resolve your issue!
  7. PhilNUK
    PhilNUK
    Dec 30, 2005
    881
    28
    +25
    would that mean having to turn your ps3 on in order to switch the hdmi over using the remote though?
    If I wanted to switch between sky and my upscaler would I have to turn on my PS3 to do that? or does it gain power even if the PS3 isn't powered up or in standby?
  8. leeA
    leeA
    Sep 9, 2005
    142
    +8
    Yes, I ran mine from the PS3, but to switch sources you have to have it switched on too......It's now running from the adapter.
  9. badassbriant
    badassbriant
    Jun 12, 2006
    308
    +13
    http://www.ebuyer.com/product/132435
    Says it need 5v to make sure it works automatically, will the following work?
    PS3
    Xbox 360 Elite
    Toshiba HD-E1
    Sky HD
    Read somewhere Sky HD doesn't work
  10. Pete_Venkman
    Pete_Venkman
    Dec 28, 2005
    +14
    From the reviews on ebuyer it seems to work great.
    The only problem mentioned is that some early Sky HD boxes don't supply the 5v to trigger the auto switch feature. The solution is to get a small ac adaptor to power the unit.
