HDMI Switch
Sparky83
I'm looking to be able to use my current keyboard/mouse, and my monitor with a Mac mini and a windows pc.
I need to be able to plug my speakers into it to. If this makes it more difficult or expensive then is there a switch for the speaker to?
Want to spend as little as possible but want one that has the cables at the rear of it but not coming out of all sides like some do.
Any thoughts
EndlessWaves
They're generally known as KVM switches (Keyboard, Video and Mouse), analogue stereo connections for speakers and microphones are common a well, but if you're using something more exotic then a separate switch is probably a better idea.
Sparky83
No nothing exotic, just my mini server and Mac mini, both with HDMI outputs as that's what my monitor is, then my standard keyboard and mouse.
Unfortunately the ones I've found that are HDMI are very expensive and others don't always have the speaker port on it or keyboard/mouse as I guess they are for tvs
