HDMI switch box
Discussion in 'Cables & Switches' started by Lil' Joe, Jan 12, 2008.
  1. Lil' Joe
    Lil' Joe
    Dec 28, 2007
    96
    Can anyone recommend an HDMI switcher 3 to 1 or 4 to 1 please. And a reasonably priced store to get it from would be good too! Thanks ya"ll..
  2. davepuma
    davepuma
    Jun 24, 2004
    17,536
    +3,506
  3. Chilly Willy
    Chilly Willy
    May 25, 2006
    380
    +75
    If you just want to connect sky/virgin box - DVD player/recorder - games consoles then try this:
    http://www.amazon.co.uk/HDMI-Tri-Link-Switcher-PS3/dp/B000NJZRSI/ref=pd_ecc_rvi_1
    Can be powered via USb port and there is a remote to select any of the three connections.
    Hope this helps :thumbsup:
  4. Hades
    Hades
    Jan 10, 2002
    11,914
    The Yorkshire Dales
    +1,184
    Hope its OK to piggy back on this thread. I was looking at the above and was wondering if it will suit my needs?
    I have 2 HDMI's on my TV... one has Sky HD the other my Denon 1920. But I have just purchased a Toshiba EP35 and will be connecting via HDMI to the TV and audio outs to receiver.
    Will this do the job without losing out on picture quality?
    Thanks,
    Gazza.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,616
    The Borders
    +3,501
    Hello Gazza UK
    In the main HDMI Switch gear either works or doesn't work - though they can sometimes cause Video signal degradation and or Audio drop out.
    Some designs are likely to work in pretty much any system - others not and will have you scratching your head wondering why.
    Have a look at Octava if you want a range of Input/Output options that tend to work in most systems - http://www.octavainc.com/
    Joe
