Hdmi switch box for hd dvd tosh player
Nic Rhodes
It seems to be the most compatible of the switch boxes because of the way it works
C
CogPaul
I am using one with absolutely no issues- highly recommended
Avi
Same here. My only comment is the blue LED's are a bit bright and may distract if the unit is visible when from the viewing position (mine isn't).
AVI
kmark40
Sorry to drag this up again, but can anybody recommend the following HDMI switches?
http://www.pixmania.co.uk/uk/uk/3914...puts-hdmi.html
http://cgi.ebay.co.uk/New-5-Port-HDM...QQcmdZViewItem
http://www.clearly-av.co.uk/SG28576R.html?id=TfjzqNEB
http://www.lindy.com/uk/productfolde...2592/index.php
I am hoping to pick up something cheap, but if it means compromising quality, then I'll have to bite the bullet. I have a Tosh 360E, HD-A1 and Tvdrive. Just a bit worried about messing up the hdmi inputs on my TV and devices from constant switching.
Thanks in advance.
Kirk
Nic Rhodes
If you want cheap look at the Octava units. I would avoid all un powered switches.
Similar threads
