blackmaverick
Established Member
Hi Guys,
I have a Panny 42PV500 and PS3/Sky HD and only 1 HDMI socket unfortunately! Can anyone recommend a good quality auto sensing splitter that I can use?
Joe Fernand
Outstanding Member
Hello blackmaverick
Its an HDMI Switch (multiple Inputs to Single Output) rather than a Splitter (Single Input to Multiple Outputs) you require.
Have a look at the Octava range - they offer Automatic source selection; see http://www.octavainc.com/
Joe
blackmaverick
Established Member
Thanks guys, just having a look now. I also had the xtreme hd hdmi switch recommended also and will compare.
Dan Walton
Established Member
I got an Octavia swithcer in readiness for my PS3 arriving last month, everything works perfectly with it, most impressed. :smashin:
staxdoobie
Established Member
This is fast turning into the Octava Appreciation Society; another vote from me. Got the 3x1 switch, works like a charm (and no picture degradation whatsoever on an HD projector). :clap:
erniebert1
Established Member
hi guys, been looking at the octava a short while now and seeing how everyone is prasing it , looks like its worth getting :)
just a quick question if anyone could kindly answer please.
Hope this doesn't sound dumb but if the switch autosenses like everyone says it does why would they need to supply a remote for it?
lee
thfccambs
lee
Good question.:confused:
It works a treat though with auto switch.Im sure Joe will answer that for you.;)
Stackers
Established Member
It only auto switches when you power up/power down a device; so if you have Sky on and then power up an HDMI DVD player it will auto switch, same when you power down.
I guess the remote would be if you kept on the DVD player but wanted to switch to Sky although I've never had to do this.
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
