HDMI splitter?
chuffster2005
I've currently got a Telewest TV Drive connected to my Tvs (only)HDMI output.I tried to connect my Samsung upscaling dvd player to the same output,using an HDMI splitter that I got from E Bay.However,I think this wasn't very good,as it seemed to "scramble"the picture of the Tv Drive(copyright protection?).
Now I'm getting an HD-Dvd player,does anyone know of any decent HDMI splitters that will let me connect the player and Tv Drive to the HDMI socket without any interference?
Nic Rhodes
What you need is an HDMI switcher, have a look at the Media Factory site of Joe F, they have a pile of the best available.
cj
I use a Gefen 4:2 HDMI splitter (for my PJ and plasma) which works great :)
Mr Fujisawa
where abouts did u get ur gefen from?
peahead
Got it from play.com but there out of stock at the mo try google it
astirling
Yeah....the thing with HDMI is if the splitter actually works then there wont be any degredation of picture. There's not much point in spending large amounts of money on switches. Cheap and cheerful is fine so long as the signal gets there intact so unless you've got large cable runs or something like that, then go for the cheaper option.
Nic Rhodes
be warned that mechanical switches don't work in all situations because of how the two way communications work with HDMI.
HeweyBoy101
Buy a decent one. After all, you only have to buy it once!
What's the point in spending loads on great kit and then scrimping on the connectors. My QED 4 way splitter has worked flawlessly for 3 months now. I purchased it at the same time as as my Plasma - essentially I saw this as part of the overall "cost" of the TV, which only had one HDMI input. Furthermore, my equipment is housed a fair distance away from my screen.
As for constantly swapping cables - I can't believe anyone would do this. What a hassle! Furthermore, HDMI is a fairly delicate and high tech electrical connection. Apart from damage to the leads / connectors, I would be concerned about damage to the HDMI circuits - look at the trouble with Pioneer recently - I know that that was a Pioneer design fault - but why take the risk?
astirling
Yeah fair point. All I'm trying to point out is that HDMI is a digital connection. It's not like component where it is essential to buy high quality cables and switchers. With HDMI you wont get loss of quality - it either works or it doesn't. As long as the signal gets their intact then a using £40 switcher will result in exactly the same picture as using a £500 switcher.
Nic Rhodes
actually it is more complicate than works or doesn't work. There are many occasions where a signal is damaged but there is still stuff on the screen. Many of these switching boxes now include circuits that help 'repair' the signal, to enable it to have broader compatibility with cables and equipment. Look to the Octava site for some good technical info on how it is done, in fact these 'techniques' are now in the HDMI 1.3 specification.
Avi
I use the Octava 3-1 that I got from Joe at TMF for about £119. Does what it says on the tin with no perceivable loss of image quality. The unit is small and features auto signal or manual input selection via remote. My unit is buried in my AV cabinet but those you plan to have it on display may want to but tape over the "bright" blue led's.
AVI
A
adlou71
Hi all,
Can someone help me? I have a TV Drive and just brought the Sony DVP-NS76H dvd player. I am looking to buy a HDMI switch box.
Anyone with any experience of the Bandridge VSB1002 switch box sold at Maplins for £69.99? or any other device cheaper or around the same price.
Adlou71
Aitch_Kay
Do a Gefen search on Ebay - plenty available :)
T800
Why do people buy the Gefen switches that are more expensive than the Octava ones and aren't automatic (I think) ?
AV Junky
cj appears to have bought the Gefen because he was looking for the 4:2 switching and signal replicating facilities. Hence up to four devices going in and then two displays running simultaneously (if needed). Technically this is quite an involved process, as the HDCP handshaking process needs to be handled. More complex of course in this case of course, as two displays to be handled simultaneously.
In general, the prices of straight-forward HDMI switchers are starting to come down, as they are becoming in demand by a larger market. Remember that companies such as Gefen started making their devices for custom installers, in days when demand was relatively low and quality requirements very high. It follows that experienced AV professionals would still prefer to use these devices, as they are familiar with them and know what they can achieve. For the home DIY user though, with relatively short cable runs to manage, etc., then the newer more affordable devices may well be quite sufficient.
PS to help avoid confusion amongst the newbies out there who may be reading this thread, might be a good idea if we're all careful with our terminology here. What we are talking about in this thread are HDMI switchers, not splitters. A splitter is a device which takes one input and spilts it into one or more outputs with the same signal. The opposite of what the OP was looking for!
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
Trending threads
Latest News
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
Samsung Galaxy Note 20 smart phone models launched
  • By Andy Bassett
  • Published
