HDMI Splitter/Switchbox?
Discussion in 'Cables & Switches' started by fordster, Oct 26, 2005.
  1. fordster
    fordster
    Aug 9, 2004
    151
    A friend of mine has only got one HDMI input on his Sharp LCD but has a DVD with HDMI output and will shortly be getting (he hopes!) Hi-Def cable from Telewest. He is looking for a way to be able to use both boxes into the one HDMI port. Has anybody got any suggestions?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,984
    The Borders
    +3,595
    Hello Fordster
    Yes install a Multi Input HDMI Switcher :)
    Your friend needs to work out if he's likely to add further Digital sources and if yes how many?
    Switchers can be 2:1, 4:1; 2x2; 4x2 etc... lots of options.
    Gefen being one manufacturer to consider - see http://www.gefen.com/kvm/hometheater.jsp
    Also does he/she require Video and Sound into the LCD screen or just Video?
    Best regards
    Joe
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,552
    Windsor
    +1,056
    spend £100+ on a HDMI splitter, or just use component out from the DVD player (might not actually be able to tell the difference anyway)
  4. fordster
    fordster
    Aug 9, 2004
    151
    Good point. He doesn't want to spend £100 and I can see his point. By the time he's spent money on cables and switches he could have just paid more money for a TV with 2 HDMI ports! I think he's already looked at the Gefen switchers and rejected them for being too expensive but thanks anyway.
