HDMI Splitter Issue
big john 1983
Established Member
Joined
Aug 10, 2008
Messages
829
Reaction score
55
Points
204
Location
Blackpool
Couldn't find anything specifically relating to my problem.....so.....
I had an Octava 1 in 2 out to allow me to connect my Samsung TV and Optoma PJ to my Onkyo amp output without having to swap leads all the time. However after a while the Octava stopped working. I gave Joe a call at TMF and he kindly offered to look at the unit for me....he did and found no fault.
I left it for ages, then decided to try a cheap unit from ebay that said it was fully HDCP compliant.
I hooked it up and it works a treat for Sky HD and the Xbox, but as soon as I try to watch my Popcorn Hour, I get no picture on either source. I have tried taking out the lead to the Xbox (to the amp) and putting it in the Popcorn......it works! I then put the original lead back in.......and it works!
So what is my problem........is it the HDCP handshake? Any thoughts?
Many thanks in advance,
John :thumbsup:
Without some (very) expensive diagnostics kit it's impossible to say for sure where the problem lies.
If your hot plugging kit you could be confusing the system - always best to power everything off at the wall whenever you are about to make a hardware change.
Joe
RESTORATION vs. REVISIONISM: At what point do 4K video and audio 'upgrades' cross the line?
Back
