hotjambalaya
Hi all have a bit of an issue that led me here, so far 2 AV guys and Neet's technical department are all a bit puzzled, so hopefully someone can think of something!
I have a simple Neet hdmi splitter, sending my sky signal to the main living room tv and the tv in the bedroom (via neet extenders & cat6).
There is no problem with the bedroom tv or signal and I can watch sky there with no problem.
The problem is that no matter what I do, I can't get a signal from the splitter to the main tv.
I have:
Plugged the bedroom tv into both outputs to see if both work, they do.
Tried 3 different HDMI cables from the living room tv into both splitter outputs, nothing.
Tried all 3 of the same HDMI cables from the living room tv, directly into the sky box, all work.
Tried using a friends HDMI splitter, with exactly the same result.
Tried them jointly and individually.
When I plug in the bedroom HDMI cable the red light activates on the splitter, it does not activate when the living room tv is plugged in.
The system all worked previously with the addition of a switcher, but at some point months ago it stopped working, I just plugged the living room tv directly into the sky box and binned the switch, its only now I'm trying to get it organised.
I don't know if its some sort of handshake issue with samsung TVs, but it worked for years previously, nothing else has been changed.
Any ideas? I'm totally lost with this one....
I have:
