HDMI Spitter and Tivo over CAT5e
Discussion in 'Cables & Switches' started by Iamnotthemessia, Mar 11, 2017.
  1. Iamnotthemessia
    Iamnotthemessia
    Mar 11, 2017
    3
    Leeds
    My house is cat5e wired and the tivo box is distributed over it. I've splitt the hdmi output from the tivo so i can watch movies in the cinema room. The cinema set up is fine since the spitter hdmi output goes directly into the amp but picture signal is lost in the tv room (cat5e distributed through hdmi to cat5e convertor) but not remote control connectivity. The splitter has a power supply although it gets its power from the tivo hdmi.If I want to watch ondemand i have to unplug the hdmi cable to the convertor and plug it into the splitter which is fine but messy but why is the signal lost through the spitter?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,540
    The Borders
    +3,254
    Does the TiVo work with the TV if you connect it directly to the Extender?
    Joe
  3. Iamnotthemessia
    Iamnotthemessia
    Mar 11, 2017
    3
    Leeds
    Yes if i take the tivo hdmi cable straight into the cat5e convertor it works fine always has. it's just now that i've introduced a splitter I've lost tv signal.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,540
    The Borders
    +3,254
    'The splitter has a power supply although it gets its power from the tivo hdmi' - are you using the PSU?
    'now that i've introduced a splitter I've lost tv signal' - possibly time to try a different Distribution Amp (Splitter).
    You could try swapping over which Display is connected to the A and B Outputs on the Distribution Amp - low cost units often 'cheat' the B Output and don't handshake properly with the attached device.
    Joe
  5. Iamnotthemessia
    Iamnotthemessia
    Mar 11, 2017
    3
    Leeds
    I have tried using the psu and power from the tivo hdmi, I also bought two splitters one expensive one from Maplins that could handle encoding etc and a cheap one from a satellite shop to no avail. I've run the tivo on its own through the splitter aswel and still no joy. The convertor is this one..
    CYP PU-106-tx Puma HDMI Over CAT (transmitter Only)
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,540
    The Borders
    +3,254
    Ideally you install a Distribution Amp (Splitter) with EDID management and the ability to update/change Firmware to deal with the type of issue you are encountering - we have our Octava HDDA12A - which is very 'robust' but not a cheap option.
    HDDA12A – The Media Factory
    Joe
